Arducam M12 Lens Set
  • SKU: MBS-Z-159
  • GTIN: 0658917599775
  • HAN: LK001
  • Category: Accessories
ArduCAM M12 Lens Set
  • ArduCam lens for Raspberry Pi camera (1/4") and Arduino
  • Telephoto lens
  • Macro lens
  • Wide-angle lens
  • Fisheye lens set (10°-200°) with M12 lens holder and cleaning Cloth
M12 Lens Kit for Raspberry Pi Cameras
This product, which includes a variety of M12 lenses for Raspberry Pi cameras, is ideal for individuals seeking precise control over their imagery and dissatisfied with standard options. It provides the ability to utilize various perspectives and focal lengths to cover a wide range of shooting scenarios.
Included in the kit are 10 M12 lenses with different perspectives, compatible with various Raspberry Pi camera models such as OV5647 and IMX219. It also includes lens holders, screws, specifications, and a cleaning cloth, ensuring you have everything you need for installation and maintenance.
To effectively utilize this kit, it is recommended to combine it with the more flexible and slightly larger camera module "Arducam B0031," specifically designed for M12 lenses. However, note that it is not directly compatible with the official Raspberry Pi Camera Module V2, as it requires a special M12 holder or an 18/20mm hole spacing on the camera board.
Using the kit is quite straightforward: simply screw the desired lens into the M12 lens holder and adjust it until you see a clear and sharp image on the video screen. Depending on the shooting situation, you can further adjust the lens. If you're unsatisfied with a lens, you can easily replace it with another.
It's important to note that the included lens holders have specific dimensions and may need adjustment depending on the lens and perspective. If you wish to use Arducam CS-mount cameras, you can also use them with this kit, but you'll need to exchange the mounts to ensure optimal functionality.
Overall, this M12 lens kit provides a practical solution for customizing and expanding your Raspberry Pi camera to meet your specific requirements and enable precise image control.
€ 119,95
Docs MYBOTSHOP documentation
