Bidirectional Brushless ESC 20A 2-4s UBEC 2A 5V
  • SKU: MBS-M-25-02
  • GTIN: 0618455047688
  • HAN: E-093
  • Category: Motordriver
Bidirectional brushless ESC
  • Plug&Play
  • Power output: 1:1
  • UBEC output
  • Different versions: 12A/20A/30A/40A/50A/60A/80A
The bidirectional brushless ESC can be used in ships, cars and underwater thrusters. The bidirectional power output is 1:1, there is no brake, offers direct return, fast response and good handling. In addition, it has a UBEC output. It is a plug&play product, accordingly, it is not necessary to calibrate the throttle stroke.
  • when using it, the remote control lever must be in the middle position (otherwise it will not be able to start)
  • the throttle stroke does not need to be calibrated
  • once the electric control is started and the engine is turning, fine adjustments can be made with the remote Control.
  • Bidirectional brushless ESC
Shipping weight: 0,05 kg
Item weight: 0,05 kg
€ 9,95
