Clearpath Robotics Husky A300 Battery Upgrade: 80Ah
  • SKU: MBS-Z-332
  • GTIN: 0658917513443
  • Category: Accessories
  • Extended operating time
  • Battery type: LiFePO₄
  • Capacity: 80 Ah at 25.6 V
  • Charging time: approx. 7-8 hours
The Clearpath Robotics Husky A300 80 Ah Battery Upgrade is a high-capacity power enhancement for the Husky A300 Unmanned Ground Vehicle (UGV). With a capacity of 80 Ah at 25.6 V, this lithium iron phosphate (LiFePO₄) battery provides significantly extended runtime, making it ideal for demanding applications that require high energy.
The 80 Ah battery upgrade delivers a substantial increase in operational duration and system performance. It is particularly suited for applications that demand high energy, such as operating manipulators or additional sensors. With this higher capacity, the Husky A300 becomes even more versatile and capable.
  • Battery Type: LiFePO₄ (Lithium Iron Phosphate)
  • Charging Time: Approximately 7–8 hours
  • Operational Runtime: Approximately 8 hours under typical usage
  • Standby Time: Up to 30 hours
  • Compatibility: Direct replacement for the standard 40 Ah battery
  • Protection Rating: IP54 (splash-resistant)
  • Operating Temperature Range: –20 °C to +40 °C
Benefits of the 80 Ah Battery Upgrade
  • Extended Runtime: Doubles the operational time compared to the standard battery, ideal for longer missions without frequent recharging.
  • Increased Power: Provides additional energy for demanding applications such as manipulators or extra sensors.
  • Optimized Charging: Charging can be efficiently managed using the appropriate charger (e.g., Delta-Q IC650).
  • Future-Proofing: Supports future expansions and higher energy demands.
Installation & Usage Notes
  • Installation: It is recommended to consider the 80 Ah battery upgrade when ordering the Husky A300, as post-purchase user installation is not supported.
  • Charger: Use the supplied charger or the optional High Power Expansion Kit for efficient charging performance.
  • Maintenance: Regularly inspect the battery for visible damage or wear.
€ 3.649,95
