CubePilot HereFlow
  • SKU: MBS-SES-62
  • GTIN: 0089336484333
  • HAN: HX4-06076
  • Category: Sensors
CubePilot HereFlow
  • Measuring range: < 2m
  • Measuring speed: 5ms
  • Interface: CAN Bus
  • Combination of LiDAR & optics
  • CubePilot compatible
The CubePilot HereFlow Sensor a small optical sensor, which is compatible to the CubePilot flight controllers via CAN bus and contributes to flight stabilization. Due to the state-of-the-art FlightSense technology this sensor can perform its measurements within 5ms and has a measuring range of up to 2m. In addition to the optical flow sensor, the HereFlow is equipped with a LiDAR and a 6D ICM20602 IMU.
Due to its extremely small dimensions of only 28.8 x 9.5mm, the HereFlow can be mounted on almost every UAV.
Technichal data
Optik
  • Optical sensor: PMW3901
  • Measuring range: < 80mm
  • FOV: 42°
  • Max. V.: 7,4 rad/s
  • Max. incident light: > 60 lux
LiDAR
  • Measuring frequency: 50Hz
  • FOV: 27°
  • Measuring range: 2m
  • Tolerance: +/- 3%
  • CubePilot HereFlow Sensor
  • CAN adapter cable
Shipping weight: 0,01 kg
Item weight: 0,00 kg
Contact data
Pixhawk Integration
€ 174,95
  • Item ordered. delivery date not yet announced by the manufacturer
