CubePilot Herelink HD Video Transmission System (V1.1)
  • SKU: MBS-DIP-09
  • GTIN: 0096718607907
  • HAN: HX4-06210 & HX4-06211
  • Category: Displays
  • Drone control & video transmission
  • Range up to 20km
  • Video transmission with 1080p @ 60FPS
  • Very low power consumption with long flight duration
  • very compact & easily portable
General
The CubePilot Herelink HD Video Transmission system consist of an Herelink controller and a Herelink Air Unit wich are connected with an 2,4GHz network. The system allows, beside the controlling of a UAV, the video transmission of up to two cameras wich can be connected via an mini HDMI port.
The Herelink controller can be used for both the steering of the UAV aswell as for live transmissioning of the videos taken via camera with a low latency of only 110ms. The Herelink controller also provides the full range of functions of QGroundControl and all data such as the telemetry data in realtime. Due to the intuitive touchscreen all functions can be used very easily.
The Herelink HD Set is supported by both Arduipilot and PX4 Flight Stack.
Furthermore the Herelink has a low power consumption of less then 4W whilst having a battery capacity of 4950mAh. Due to the persistent battery the large range of functions the Herelink has to offer can be used for several hours.
Technical Data
HX4-06211 Herelink Controller Unit
  • 1 x Herelink Controller Unit
  • 2 x Herelink Controller Joystick
  • 1 x Herelink Omni-directional Antenna
  • 1 x Herelink Directional Antenna
HX4-06210 Herelink Air Unit
  • 1 x Herelink Air Unit
  • 1 x Herelink Mounting Plate
  • 1 x Herelink Screw Set
  • 1 x Herelink Fan
  • 1 x Herelink Cable Set
  • 1 x Herelink HDMI Cable
Shipping weight: 1,00 kg
Item weight: 0,52 kg
Contact data
€ 2.019,95
  • Currently out of stock
Docs MYBOTSHOP documentation
