DOBOT Conveyor Belt Kit
  • compatible with the DOBOT Magician robotic arm
  • Maximum payload of 500g
  • Maximum Speed of 120mm/s
The DOBOT Conveyor Belt Kit is perfectly fitting to emulate production processess when used with the DOBOT Magician robotic arm. The controlling can be done intuitive via an graphical software enviroment or be programmed.
  • Weigt: 4,2Kg
  • DImensions: 785 x 285 x 85mm
  • Maximum Payload: 500g
  • length: 600mm
  • Maximum Speed: 120mm/s
  • Maximum Acceleration: 1100mm/s
  • Distance sensor: 20 - 150mm
  • Color sensor: recognizes colored objects
  • Conveyor
  • Distance sensor
  • Color sensor
  • Tool kit
  • 40 colored wooden cubes
  • Demo Position map
Shipping weight: 7,00 kg
Item weight: 5,00 kg
€ 479,95
