ELRS Receivers Series | RP3 ELRS Nano Receiver
  • SKU: MBS-HOLY-03
  • GTIN: 0658917510909
  • HAN: 31168
  • Category: Accessories
RadioMaster RP Series Receivers | RP3 ELRS Nano Receiver
  • Uses ExpressLRS 2.4 GHz firmware with ESP8285 MCU and SX1280IMLTRT RF chip for long range and low latency.
  • Wi-Fi for easy firmware updates. Binding simplified with a bind phrase—no bind plugs needed.
  • RP3 features LNA, up to 100mW telemetry, and antenna diversity. Also available in RP1 and RP2.
The RadioMaster RP series receivers are designed with a focus on size, ease of use, and range. The RP series of nano receivers utilizes ExpressLRS 2.4 GHz open-source firmware, delivering the features and range that today’s pilots expect.
Featuring the ESP8285 MCU and SX1280IMLTRT RF chip, the RP receivers offer Lora and FLRC 2.4 GHz RF links for incredible range and low latency. With built-in Wi-Fi, firmware updates can be done directly on your craft without removing the receiver. Binding is done using a bind phrase, eliminating the need for bind plugs and tricky button presses.
The RP3 receiver features a Skyworks SE2431L providing an LNA for improved reception and a PA for up to 100mW telemetry performance, along with antenna switching for diversity. We also offer the RP1 and RP2 receivers.
Specifications:
  • RF Chip: SX1280IMLTRT
  • MCU: ESP8285
  • RF Link: Lora and FLRC 2.4 GHz
  • Telemetry Power: Up to 100mW
What's in the Box:
  • 1 x RP3 ExpressLRS 2.4 GHz Nano Receiver
  • 2 x 65 mm UFL 2.4 GHz T Antennas
  • Documentation
Contact data
€ 35,64
  • Currently out of stock
