FLIR thermal imaging camera
  • SKU: MBS-FLIR-07
  • Category: Sensors
FLIR Thermal Camera
  • E52 | E6 Pro
  • Electrical inspections and building diagnostics
  • Thermal resolution: 240 × 180 pixels
FLIR E52
The FLIR E52 is a professional thermal imaging camera designed for electrical, mechanical, and building inspections. It helps detect temperature differences quickly and identify potential faults in equipment and structures. Features such as manual focus, MSX image enhancement, and cloud connectivity allow accurate thermal analysis and easy documentation of inspection results.
Technical Data
  • Thermal sensitivity: < 50 mK
  • Spectral range: 7.5 – 14 µm
  • Frame rate: 30 Hz
  • Field of view: approx. 33° × 25°
  • Focus: manual
  • Minimum focus distance: approx. 0.15 m
  • Display: 4" LCD touchscreen, 640 × 480 pixels
  • Digital camera: 5 MP
  • Temperature range: −20 °C to 120 °C / 0 °C to 550 °C
  • Accuracy: ±2 °C or ±2 % of reading
  • Digital zoom: up to 4×
  • Image modes: Thermal, MSX, Picture-in-Picture
  • Connectivity: Wi-Fi
  • Operating temperature: −15 °C to 50 °C
Scope of Delivery
  • FLIR E52 thermal imaging camera
  • Lithium-ion batteries
  • Battery charger
  • Power supply
  • Hard carrying case
  • Lens cap
  • Shoulder and hand straps
  • SD memory card
  • USB and HDMI cables
  • Software and documentation
FLIR E6 Pro
The FLIR E6 Pro is a compact thermal imaging camera for maintenance, electrical inspections, and building diagnostics. It provides clear thermal images and uses MSX technology to enhance detail by combining visual and thermal information. The camera supports wireless connectivity and allows quick identification of temperature anomalies during inspections.
Technical Data
  • Thermal sensitivity: < 0.06 °C
  • Spectral range: 7.5 – 13 µm
  • Frame rate: 9 Hz
  • Focus: fixed focus
  • Display: 3.5" color LCD, 640 × 480 pixels
  • Temperature range: −20 °C to 550 °C
  • Battery runtime: approx. 4 hours
  • Protection rating: IP54
Scope of Delivery
  • FLIR E6 Pro thermal imaging camera
  • Lithium-ion battery
  • Power supply and charger
from
€ 2.399,95
