Fictionlab Leo Rover Sandwich Plate
- SKU: MBS-Z1-106
- GTIN: 0658917510787
- Category: Accessories
Manufacturers:
With this elevated mounting plate, you can optimize the setup of your rover by adding an additional mounting surface above LiDARs, cameras, and other components. This plate is a modified version of the standard mounting plate, but with an elevated position.
Product Contents
- 1x Mounting Plate (with through holes - 7 mm Ø)
- 8x M5 threaded spacers - 40 mm long (different from the photos)
- 4x M5x10 mounting screws
With these components, you can raise the mounting plate either 40 mm or 80 mm above the original mounting plate. The assembly is very simple and based on the existing threaded inserts of the mounting plate.
Notes
- The LiDAR, stereo vision camera, and USB hub shown in the photos are not included in the offer.
- This add-on could slightly reduce the range of the rover, as the plate may act as a shield for the WiFi signal.
