Holybro Kakute H7 v1.5 Tekko32 F4 Metal 4in1 65A ESC Stack
Holybro Kakute H7 v1.5 Tekko32 F4 4-in-1 50A ESC Stack
  • The set consists of Kakute H7 v1.5 and Tekko32 F4 4-in-1 50A ESC
Holybro Kakute H7 V1.5
The Kakute H7 V1.5 is a high-performance flight controller for FPV drones, designed for fast processing, precise sensors, and versatile connectivity. It is ideal for racing, freestyle, and high-performance builds.
Key Features
  • Powerful 32-bit STM32H7 processor (high processing power and stability)
  • IMU: ICM-42688-P with integrated barometer for accurate attitude and altitude measurement
  • Built-in Bluetooth, compatible with SpeedyBee App for wireless setup
  • Multiple UARTs, JST-SH ports, USB-C, MicroSD (Blackbox logging)
  • Supports 2S–8S LiPo, provides 5V/2A and 9V/3A BEC outputs
  • Compact form factor (30.5 × 30.5 mm), lightweight – perfect for space-constrained builds
Ideal for: FPV racing, freestyle, high-performance setups
Tekko32 F4 Metal 4-in-1 65A ESC (AM32)
The Tekko32 F4 Metal 4-in-1 65A ESC is a compact and robust power ESC designed for high continuous current and aggressive flight. Its metal casing, high-quality MOSFETs, and large capacitors provide reliable power even under heavy loads.
Key Features
  • F4 MCU for fast ESC control and clean signal processing
  • Continuous current up to 65 A per channel, with high burst capacity (depending on specifications)
  • Metal casing and large MOSFETs for excellent heat dissipation
  • High-capacity capacitors for stable power and reduced voltage sag
  • Supports popular protocols: DShot (including 1200), MultiShot, OneShot, etc.
  • 4-in-1 design saves space and reduces weight/wiring complexity
Ideal for: high-performance FPV quads, long-range setups, heavy-lift configurations, and any builds requiring high current capacity and reliable ESC performance.
€ 174,95
