Holybro M9N GPS 6Pin - 2nd GPS
  • SKU: MBS-SES-177-01
  • GTIN: 0618455045448
  • HAN: 12029
  • Category: Electronics
Holybro M9N GPS 6 Pin
  • Features UBLOX M9N module
  • Integrated IST8310 compass
  • Three-colour LED display
  • Safety switch
  • Choice of 3 different connection types
M9N GPS has a UBLOX M9N module, an IST8310 compass, a three-colour LED display and a safety switch. There are 3 different connection options for different purposes.
The baud rate of this module is 115200 5Hz.
Features & Specifications
  • Ublox Neo-M9N Module
  • Industry leading navigation sensitivity of
  • 167 dBm - Cold start: 26s
  • LNA MAX2659ELT+
  • 25 x 25 x 4 mm ceramic patch antenna
  • Rechargeable Farah capacity
  • Low-noise 3.3 V regulator
  • Power consumption: less than 150 mA at 5 V
  • Fixed indicator LEDs
  • Protective housing
  • 26cm cable included
  • Overall diameter 50mm, 32 grams with housing
 Dimensions
  • 1x M9N GPS module
  • 1x X" type foldable base mount
  • 1x carbon rod 70mm & 140mm
  • 1x adhesive surface
  • 4x screws
  • 4x nuts
Connection
€ 89,95
