Holybro Micro M9N GPS w/ case
  • SKU: MBS-SES-398
  • GTIN: 0618455052859
  • HAN: 12046
  • Category: UAV / Pixhawk
  • Ublox M9N GNSS Receiver
  • IST8310 Compass
  • rechargeable Backup Battery
Holybro's Micro M9N GPS is equipped with the Ublox M9N GNSS chip and the IST8310 digital compass. This provides a convenient method of mounting the compass, away from any sources of interference. It also features an active circuit for the ceramic patch antenna and a rechargeable backup battery for warm start.
  • Ublox M9N GNSS Reciever
  • Fast & Accurate Positioning
  • IST8310 Compass
  • Small Form Factor
  • GNSS Receiver: Ublox M9N Receiver
  • Concurrent GNSS: upt to 4 GNSS
    • BeiDou
    • Galileo
    • GLONASS
    • GPS
    • QZSS
  • Compass: IST8310
  • Frequency Band:
    • GPS L1
    • Galileo E1
    • GLONASS L1
    • BeiDou B1
    • SBAS L1
    • QZSS L1
  • Output Control: UBX (U-blox) | NMEA
  • Nav. Update Rate: up to 25Hz
  • GNSS Augmentation System: EGNOS, GAGAN, MSAS and WAAS supported | QZSS: L1S
  • Default baud rate: 38400
  • Input Voltage: 4,7 - 5,2V
  • Velocity Accuracy: 0,05 m/s
  • Port type: JST-GH-6P
  • Antenna: 25x25x4 mm ceramic patch antenna
  • Power Consuption: less than 200mA @ 5V
  • Operating Temperature:n -40 ~ 80°C
  • Dimension: 32 x 26 x 9 mm
  • Weight: 14g
  • Others: LNA MAX2659ELT+ RF Amplifier | Rechargeable Farah capacitance | Low noise 3,3V regulator
  • 1x Micro GPS module
  • 1x JST GH 6 Position Connector 15cm
  • 1x JST-GH 6pin colored Silicon cable 15cm
Shipping weight: 0,30 kg
Item weight: 0,02 kg
€ 49,95
