Holybro X500 V2 UAV Kit
The Holybro X500 V2 ARF Kit is a carbon fiber drone kit that can be assembled in a short time (about 15 minutes).
Scope of delivery:
1. X500 V2 frame kit.
- Body: full carbon top and bottom plate (144x144 mm, 2 mm thick).
- Arm: 16 mm carbon fiber tubes with fiber reinforced nylon connectors
- Chassis: 16 mm and 10 mm diameter carbon fiber tubes with improved and reinforced plastic tees
- Platform board: mounting holes for GPS and companion computers like Raspberry Pi 4 and Jetson nano
- dual 10 mm diameter rod
- 250 mm long rail mounting system
- Battery holder (with 2 battery straps)
- hand tool (for installation)
2. X500 V2 ARF Kit
- X500 V2 frame kit
Pre-installed elements ?4x motors - Holybro 2216 KV920 motor.
- 4x controller - BLHeli controller
- 6x 1045 propeller
- Power Distribution Board - XT60 connector for battery & XT30 connector for controller & peripherals.
Mechanical data:
- wheelbase: 500 mm
- motor mount pattern: 16x16 mm
- frame body: 144x144 mm, 2 mm thick
- chassis height: 215 mm
- distance between upper and lower plate: 28 mm
- weight: 610 g
Product weight: | 0,61 Kg |
