Intel® RealSense Depth Modul D410
  • SKU: MBS-SES-143
  • GTIN: 0618455047336
  • HAN: 82635DSASRPRQ 951913
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Module D410 (BULK)
  • Intel®RealSense™
  • diagonal field of view over 70°
  • two global shutter sensors for depth streaming at up to 30 frames/s
  • range 0.3 m to over 10 m (varies depending on lighting conditions)
  • 50 pin connector
Software
  • Intel®RealSense™
  • 50 pin connector
  • Intel RealSense Depth Module D410 (BULK)
Intel® RealSense Depth Modul D410 Datasheet
Price on request
