Intel® RealSense Depth Modul D450
  • SKU: MBS-SES-147
  • GTIN: 0618455047374
  • HAN: 82635DSD450 999WCM
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Module D450 (BULK)
  • Intel®RealSense™
  • up to 1280 x 800 RGB resolution
  • two global shutter sensors for depth streaming at up to 30 frames/s
  • range 0.2 m to over 10 m (varies depending on lighting conditions)
  • 50pin connector
Software
  • Intel®RealSense™
  • 50pin connector
  • Intel RealSense Depth Module D450 (BULK)
Intel® RealSense Depth Modul D450 Datasheet
Price on request
