Inventables PCB Drill Set
  • SKU: MBS-IN-07
  • GTIN: 0049438166681
  • HAN: 30326-01
  • Category: Factory
  • 10 drill bits
  • drill diameter: 0,3 - 1,2mm
The Inventables Bit Sets are optimized for use with X-Carve and the corresponding CAM software. Thus, the shank fits perfectly into the chuck of the spindle and enables a frictional connection. In addition, the appropriate cutter can be selected in the Easel CAM software, whereby various parameters can be preset according to the cutter. This enables perfect results as well as gentle material handling.
  • 0.30mm/0.012"
  • 0.40mm/0.016"
  • 0.50mm/0.020"
  • 0.60mm/0.024"
  • 0.70mm/0.028"
  • 0.80mm/0.031"
  • 0.90mm/0.035"
  • 1.0mm/0.039"
  • 1.1mm/0.043"
  • 1.2mm/0.047"
Shipping weight: 0,05 kg
Item weight: 0,04 kg
€ 24,99
Docs MYBOTSHOP documentation
