The Kinova Gen3 Table Mount Main Plate is a high-quality mounting solution designed specifically for the Kinova Gen3 robotic arm. This robust main plate allows you to securely and stably mount the robot arm on a table surface for optimal working conditions. Important, it is only the main plate on which the Gen3 is screwed.
- 1x Kinova Gen3 table mounting main plate
