Kinova Mounting Kit
  • SKU: MBS-KNV-22
  • GTIN: 0658917504991
  • HAN: XK 0000 0014
  • Category: Accesoires
Kinova Mounting Kit
  • Mounting plate, mounting column, 2 clamps
  • quick and secure fixing
Kinova Mounting Kit (XK 0000 0014) – Mounting Kit for Kinova Robot Arms
The original Kinova mounting kit enables quick and secure mounting of a Kinova robot arm on tables, workbenches, and other flat surfaces or mobile platforms. The kit consists of a sturdy mounting plate and a mounting post onto which the robot arm is placed.
Two fixing options are available: the mounting plate can either be clamped to the edge of a solid work surface using the two supplied clamps, or permanently secured with four M12 screws through the holes in the plate. The post is mounted on the plate simply using an 8 mm hex key – ideal for flexible use in laboratory, research, and development environments.
Highlights
  • Secure mounting of the robot arm on flat surfaces and mobile platforms
  • Two fixing options: clamping with the supplied clamps or bolting with four M12 screws
  • Quick assembly with an 8 mm hex key
  • Ideal for changing setups in laboratory, teaching, and research
Technical Data
Product type Mounting kit
Manufacturer Kinova
Manufacturer part number XK 0000 0014
Components Mounting plate, mounting post, 2 clamps
Fixing Clamping with clamps or 4 × M12 bolting
Required tool 8 mm hex key
Compatibility Kinova Gen2 robot arms
Scope of Delivery
  • 1 × Mounting plate
  • 1 × Mounting post
  • 2 × Clamp
Price on request
  • Must be ordered. Ready for shipment in 40 days after order.
