Lightware Communication-/Power cable for SF000
  • SKU: MBS-Z-363
  • GTIN: 0658917505028
  • HAN: HPN-3795-1
  • Category: Accessories
Lightware communication/power cable for SF000
  • Length: 29.5 cm
  • 6-pin connector
The LightWare HPN-3795-1 is the communication and power cable (295 mm) for the SF000/B. It is the standard connection cable for the sensor and is also available as a spare/accessory cable.
The cable carries the power supply and the communication signals, and connects to the sensor via a six-position connector.
In combination with the LightWare DroneCAN adapter, the HPN-3795-1 serves as the matching connection cable between the adapter and the SF000.
Technical specifications
Type Communication and power cable
Length 295 mm
Compatible with SF000/B
Connector (sensor side) 6-position
Transmitted signals power supply, communication signals
  • 1× LightWare HPN-3795-1 communication and power cable (295 mm) for SF000
Shipping weight: 0,20 kg
Item weight: 0,10 kg
€ 8,99
