LiteBee Wing – 4 x Educational Programmable Drones - Classroom kit
  • SKU: MBS-DR-70
  • GTIN: 0658917504922
  • Category: Drones
  • 4 programmable educational drones as a complete class set for STEM education
  • Programming via block coding & Python; swarm / formation flight via QR code mat
  • Ready to use incl. spare parts, charger and ABS rolling flight case
The LiteBee Wing classroom set bundles four programmable indoor educational drones from Makerfire into a ready-to-use class set for STEM education. Students get a playful introduction to programming, robotics and flight physics – from first flight attempts to their own programs.
The drones are programmed using graphical block coding as well as Python, so the difficulty can be matched to the respective learning level. Via the included QR code mat (3 × 3 m) and the WiFi connection, formation and swarm flights of several drones are also possible. The attachable LED module additionally enables programmable light shows.
Thanks to Lego Technic compatibility (pins, beams, dots) the drones can be individually extended. Plenty of spare parts (propellers, motors) and a rugged ABS rolling flight case make the set especially practical for everyday classroom use.
Product type programmable indoor educational drone (class set, 4 drones)
Manufacturer Makerfire
Programming graphical block coding and Python
Connection / control WiFi (via included controller and router)
Positioning optical via QR code mat (3 × 3 m); formation / swarm flight
Expansion attachable LED module; Lego Technic compatible
Power supply lithium batteries (8 pcs) + S20 multi-charger
Transport ABS rolling flight case
  • 4× LiteBee Educational Drone
  • 1× S20 Multi-Lithium Battery Charger
  • 1× QR code mat (3 × 3 m)
  • 1× TP-Link router
  • 8× lithium battery
  • 4× LED module
  • 1× WiFi controller
  • 4× USB cable
  • 1× propeller disassembly tool
  • 4× spare propellers (2 CW / 2 CCW)
  • 4× spare motors (2 CW / 2 CCW)
  • 14× Lego Technic pin (standard: 10; half: 4)
  • 4× Lego Technic beam 1×5
  • 10× yellow Lego dot
  • 10× JST 4-pin connection cable
  • 1× user manual
  • 1× ABS rolling flight case
€ 2.142,00
Docs MYBOTSHOP documentation
