MANUS Sensor Gloves for Metagloves Pro Haptic
  • M or L
  • a good fit, washable
The Sensor Gloves are the textile gloves of the MANUS Metagloves Pro Haptic – the part worn directly on the hand that holds the detachable Haptic Top Module. Together they form the modular "one top module, many users" concept: while the top module contains all the electronics, the personally fitting, washable sensor gloves ensure hygienic and comfortable use – ideal for multi-user setups in which each user wears their own size-appropriate glove.
The sensor gloves hold the fingertip sensors and route the fully integrated cabling – for a clean, robust setup without loose cables. Thanks to persistent calibration profiles, no recalibration is required when switching between users or gloves.
This item is intended as a sensor glove component for the Metagloves Pro Haptic – ideal as a replacement, an additional size or to expand a multi-user setup in combination with the top module.
  • Metagloves Pro Haptic – Sensor Gloves (1 pair, left/right)
Note: Textile sensor gloves only – without top module, battery or dongle.
Size
€ 3.094,95
Docs MYBOTSHOP documentation
