MAUCH 082 BEC HS 2-6S BEC / 5,35V-3A / DF-13-4P
MAUCH HS-Series BEC
  • BEC, HYP-BEC & Backup BEC
  • 2-6S 28V | 4-14S 60V
  • 3A Output
The MAUCH HS BEC modules are divided into primary and secondary BEC modules. So the HYP-BEC & BEC is connected to the Power 1 port while the backup BEC's are connected to the Power 2 output.
Technical Data
  • Output: 3,35V / 3A > +/- 0,05V
  • Ripple: 10mV (0.2%) at 1.5A output current
  • Size: 47 x 18 x 11 mm
  • Weight: 8g (with cable and heat shrink tube)
  • MAUCH 082 BEC HS 2-6S BEC / 5,35V-3A / DF-13-4P
Shipping weight: 0,16 kg
Item weight: 0,01 kg
€ 40,95
