Makera Cyclone Dust Collector
Makera cyclonic vacuum cleaner
  • maximum 70dB
  • cyclonic system
  • two-stage suction system
Dual-Stage Continuous Dust Collection
  • Engineered for Milling: Makera’s dual dust collection system (cyclone separation + multi-stage filtration) reliably captures chips and particles during machining. This eliminates cleanup pauses and allows your CNC to operate virtually debris-free.
Industrial-Grade Cyclone System
  • Makera sets new standards for desktop CNCs with a professional-grade cyclone system: 97% of large chips are diverted directly into the dust bin before reaching the filters. This extends filter lifespan by up to three times and enables uninterrupted operation—without clogs or frequent filter replacements.
Three-Stage Filtration
  • Pre-filter sponge, 99.99% HEPA filter, and activated carbon: this system removes virtually all fine dust while neutralizing odors. You’ll breathe easier and work in cleaner air for a healthier environment.
Whisper-Quiet Operation
  • With a maximum of just 70 dB—significantly quieter than conventional external dust extractors—the unit is ideal for use in homes, offices, or classrooms without ear fatigue or disturbance to others.
Basic Information
  • Dimensions: 300 × 218 × 354 mm
  • Package Dimensions: 370 × 270 × 425 mm
  • Gross Weight: 8 kg
  • Color: Silver
  • Material: Aluminum alloy + plastic parts
Performance Parameters
  • Dust Collection Type: Cyclone separation + multi-stage filtration
  • Dust Bin Capacity: 6 L
  • Max Vacuum Pressure: 12 kPa
  • Max Airflow: 900 L/min
  • Filtration System: Pre-filter + HEPA filter + activated carbon filter
  • Filtration Efficiency: 99.99%
  • Max Noise Level: 70 dB
  • Control Method: Manual app control + automatic G-code triggered control
  • Protection Rating: IP54
  • Dust collection hose
  • Pre-filter sponge
  • Data cable
  • Power cord
  • User manual
Shipping weight: 10,00 kg
Item weight: 8,00 kg
€ 929,99
