Makera Epoxy Tooling Block
  • various sizes
  • Ideal for Makera Carvera
The Makera Epoxy Tooling Block is an extremely versatile and high-performance material made of dense and homogeneous epoxy resin, widely used in the manufacturing, prototyping, and tooling industries. Thanks to its uniform structure, the Epoxy Tooling Block enables precise and reliable machining, with material properties remaining consistent across the entire surface.
Available in the following sizes:
Dimensions: 35mm x 35mm, 50mm x 50mm
Length: 100mm, 200mm
Perfect for demanding applications where precision and consistency are key.
Dimension
Length
from
€ 10,90
