Martian ll Quadcopter Frame
  • SKU: MBS-DR-18
  • Category: Drones
Martian II Quadcopter Frame
  • 7" 295mm and 8" 355mm
  • Carbon fiber
  • custom aluminum hardware > quick arm replacement
  • arm thickness: 4mm
The quadcopter frames are made of carbon fiber and have custom aluminum hardware. The frames have multiple motor mounting holes for a variety of motors. A PDB with XT60 connector is included.
  • 3K carbon fiber frame
  • 4mm removable arms
  • Custom aluminum hardware for quick arm replacement
  • Multiple motor mount extinguishers
  • PDB with XT60 connector
  • easy LiPo access
  • Supports 32mm board cams (like HS1177)
  • Supports HD Cameras (like GoPro 4, Runcam 2 or GoPro Session)
Technical data7" 295mm Frame
  • Wheelbase: 295mm
  • Material: Carbon Fiber
  • Arm thickness: 4mm
  • Thickness of the plates: 1,5mm each
  • Weight: 145g +/- 2g
Technical data 8" 335mm Frame
  • Wheelbase: 335mm
  • Material: Carbon fiber
  • Weight: 160g +/- 2g
  • 1x frame kit (unassembled)
  • 1x power distribution board
  • 1x battery belt
  • 4x 22XX motor protection cover
from
€ 35,95
  • Available immediately
Docs MYBOTSHOP documentation
