Marvelmind Modem Outdoor v4.9
  • SKU: MBS-SES-54
  • GTIN: 0618455048159
  • HAN: 4680038530371
  • Category: Sensors
  • IPx7 Protected (30min into 1m Water)
  • 433MHz Radiofrequency
  • Designed for up to 1000m²
  • Supports up to 255 Beacons
  • Distance with a small antenna: < 100m | 165mm Antenna + 38kbps: < 400m
The Marvelmind Modem is one of two parts that enable a very precise indoor navigation with a tolerance of only 1-3% / ±2cm, the other part that is required, is the Marvelmind Beacon. The system is designed to precisely make out the position of both UAV's & AGV's, but also of other objects that have a beacon attached to it. The Marvelmind system is based on an 433MHz radio frequency combined with the latency of ultrasonic sensors.
Special Features
  • 3D Positioning if 3 Beacons are used
  • 2D Positioning if 2 Beacons are used
  • Recommended Distance 30m | capable of up to 50m
Technical Data
  • Space: < 1000m²
  • Latency: ±2cm
  • Localisation speed: 0,05 - 45Hz
  • Interfaces: UART, USB & I2C
  • 1 x Outdoor Modem incl. Antenna
The user manual, configuration exemples aswell as additional technical data can be found HERE.
Shipping weight: 0,07 kg
Item weight: 0,02 kg
€ 154,95
