Metal Bracket (IR-MB05) - Dedicated only for 17Lf (27mm stroke) Lateral Mounting
  • SKU: MBS-ME-103
  • GTIN: 0658917505004
  • HAN: IR-MB05
  • Category: Mechanic
MightyZAP Linear Servomotor Bracket
  • iRRobot part number: IR-MB05
  • Metal mounting bracket / fastening
  • Exclusively for 17Lf (27 mm stroke) with side mounting
The IR-MB05 is a specially designed metal bracket for lateral mounting of mightyZAP linear servos from the 17Lf series with 27 mm stroke. It enables horizontal mounting of the actuator without restrictions on installation orientation and ensures stable and flexible integration into applications.
The bracket is exclusively designed for this series and is not compatible with other mightyZAP models. For safe installation, the included screws should be used and the installation instructions must be followed.
Technical Data
Specification Value
Product type Metal bracket for lateral mounting
Compatibility Exclusively 17Lf series (27 mm stroke)
Mounting type Horizontal / lateral
Material Metal
Features Installation without orientation restrictions possible
Compatibility limitation Not suitable for other mightyZAP series
  • 1x IR-MB05 metal bracket
  • Mounting screws (4x spacer, 4x screw M2xL4, 4x screw M2xL3, 1x screw M2.5xL6)
Shipping weight: 0,10 kg
Item weight: 0,03 kg
€ 24,99
Docs MYBOTSHOP documentation
