Movella MTi-680 RTK GNSS/INS Development Kit
  • SKU: MBS-MOV-07
  • GTIN: 0658917501556
  • HAN: MTi-680-DK
  • for applications in the fields of robotics, virtual reality, autonomous driving
  • Standard full range [°/s] ±2000
  • Bandwidth (-3dB) [Hz] 520
The MTi-680-DK is a comprehensive development kit that provides you with an excellent solution for precise motion and orientation measurements. Developed by Xsens Technologies, a leading provider of inertial sensing technology, the MTi-680-DK is ideal for applications in robotics, virtual reality, autonomous driving and many others.
The development kit includes the high-performance MTi-680 IMU module, which is equipped with best-in-class sensors such as gyroscopes, accelerometers and magnetometers. These powerful sensors enable accurate real-time motion capture and orientation information. With the MTi-680-DK, you have the ability to perform complex motion and orientation measurements in your projects. The set offers a wide range of functions, including calculation of 3D position, velocity, acceleration and rotation angle. Thanks to the advanced sensor fusion technology, you get precise and reliable data for accurate motion analysis.
The MTi-680-DK features easy integration and ease of use. It supports various communication interfaces such as UART, SPI and I2C to ensure seamless integration with your existing systems. In addition, a comprehensive software suite is available to help you harness the full power of the MTi-680-DK and develop customized solutions for your requirements.
With the MTi-680-DK, you can accelerate your development process and take your projects to a new level. Experience precise motion and orientation measurements like never before and realize innovative applications in robotics, VR and much more.
Specification:
  • Stability of preload during run [°/h] 8
  • Noise density [°/s/vHz] 0.007 g-sensitivity (calibrated) [°/s/g] 0.001 Non-linearity [%FS] 0.1
  • Scale factor deviation [%] 0.5 (typical) 1.5 (over lifetime)
Further information on the specifications can be found in the data sheet.
Scope of delivery:
  • 1x MTi-630 Development Kits
Shipping weight: 2,00 kg
Item weight: 0,98 kg
€ 2.485,95
