Movella Rugged AHRS Starter Kit
  • SKU: MBS-MOV-05
  • GTIN: 0658917501532
  • HAN: MTi-630R-SK
  • Sensor kit for motion tracking and orientation detection
  • Standard full range [°/s] ±2000
  • Stability of bias during run [°/h] 8
  • Bandwidth (-3dB) [Hz] 520
The MTi-630R Starter Kit is an advanced sensor kit developed by Xsens Technologies. It is specifically designed for applications that require extremely precise motion tracking and orientation detection. With this kit, you get a comprehensive solution to capture accurate motion, position and orientation data.
The kit includes the MTi-630R sensor, which is equipped with a number of high-precision sensors such as accelerometers, gyroscopes and magnetometers. These components work together to provide accurate, real-time measurement data and reliable motion tracking. With the MTi-630R-SK, you can capture and track motion in six degrees of freedom (6DOF). Whether you're in robotics, automotive, virtual reality, or motion analysis, this sensor kit gives you the precise data you need to accurately capture and analyze motion.
The MTi-630R-SK stands out not only for its precise measurements, but also for its easy integration into existing systems. It offers various communication interfaces, such as UART, SPI, and I2C, to enable seamless connectivity to your applications. In addition, the MTi-630R-SK is rugged and reliable, even in demanding environments. With its rugged package and excellent shock and vibration resistance, it is suitable for use in a variety of industrial environments.
Experience the precision and performance of the MTi-630R-SK and optimize your motion tracking and orientation sensing applications. With this high-quality sensor kit, you are assured of accurate and reliable data for your applications.
Specifications:
  • Stability of preload during run [°/h] 8
  • Noise density [°/s/vHz] 0.007 g-
  • Sensitivity (calibrated) [°/s/g] 0.001
  • Nonlinearity [%FS] 0.1
  • Scale factor deviation [%] 0.5 (typical) 1.5 (over lifetime)
Further specifications can be found in the data sheet
Scope of delivery:
  • 1x MTi-630 Development Kits
Shipping weight: 1,50 kg
Item weight: 0,85 kg
€ 2.224,95
