Movella Rugged GNSS/INS
  • SKU: MBS-MOV-08
  • GTIN: 0658917501563
  • HAN: MTI-670G
  • advanced Inertial Measurement Unit (IMU)
  • Standard full range [°/s] ±2000
  • Stability of preload during run [°/h] 8
  • Bandwidth (-3dB) [Hz] 520
The MTI-670G is an advanced Inertial Measurement Unit (IMU) developed by Xsens Technologies.
With this device, you can accurately capture and track motion and position in real time. Whether you are in robotics, virtual reality, game development, or animation, the MTI-670G provides you with a powerful tool to take your projects to the next level. With its advanced sensor fusion algorithm and a combination of high-precision accelerometers, gyroscopes and magnetometers, the MTI-670G provides accurate and reliable data.
This precision allows you to track the movement of your object or body in real time and integrate it into your applications. The MTI-670G stands out for its versatility. It can be used for both free motion and bound applications. The device offers wireless connectivity and can seamlessly connect to multiple platforms and systems. With its user-friendly interface and easy integration, the MTI-670G makes setup quick and straightforward.
Whether you want to create realistic motion in virtual reality, precisely control animated characters, or capture complex motion patterns in robotic systems, the MTI-670G provides the tools you need. Rely on the precise measurements and high performance of this innovative IMU to add a new dimension of motion capture to your applications.
Specification:
  • Noise density [°/s/vHz] 0.007 g-sensitivity (calibrated) [°/s/g] 0.001 Non-linearity [%FS] 0.1
  • Scale factor deviation [%] 0.5 (typical) 1.5 (over lifetime)
Further information on the specifications can be found in the data sheet.
Scope of delivery:
  • 1x MTi-630 Development Kits
Shipping weight: 1,50 kg
Item weight: 0,85 kg
€ 3.461,95
