Movella Rugged RTK GNSS/INS Starter Kit
  • SKU: MBS-MOV-11
  • GTIN: 0658917501594
  • HAN: MTi-680G-SK
  • Standard full range [°/s] ±2000
  • Stability of bias voltage during run [°/h] 8
  • Bandwidth (-3dB) [Hz] 520 Noise density [°/s/vHz]
The ultimate solution for precise 3D motion and orientation measurements. The MTi-680G-SK is a state-of-the-art, high-performance inertial measurement device designed specifically for applications that require the highest accuracy and reliability. With its innovative sensor fusion technology and a variety of sensors, including gyroscopes, accelerometers and magnetometers, the MTi-680G-SK provides extremely accurate measurement data for real-time motion and orientation tracking. With impressive accuracy and an extended measurement range, the MTi-680G-SK enables reliable detection of 3D motion, rotation rates, and magnetic fields.
Whether in robotics, aerospace, automotive or other demanding applications, the MTi-680G-SK ensures you always get the most accurate data for precise control and motion tracking. With its rugged design and advanced sensor fusion technology, the MTi-680G-SK delivers reliable and accurate data even under extreme conditions and vibration.
With its advanced communication interfaces, such as CAN and RS232, the MTi-680G-SK enables seamless integration into various systems and platforms. In addition, the MTi-680G-SK offers extensive configuration options and a user-friendly software interface for easy customization and programming of the device according to your specific requirements.
Specification:
  • Stability of preload during run [°/h] 8
  • Noise density [°/s/vHz] 0.007 g-sensitivity (calibrated) [°/s/g] 0.001
  • Nonlinearity [%FS] 0.1 Scale factor deviation [%] 0.5 (typical) 1.5 (over lifetime)
Further information on the specifications can be found in the data sheet.
Scope of delivery:
  • 1x MTi-630 Development Kits
Shipping weight: 2,00 kg
Item weight: 0,98 kg
€ 4.116,95
