Movella Xsens Vision Navigator Starter Kit - Ruggedized 2-Antenna RTK GNSS/VINS
  • SKU: MBS-MOV-12
  • GTIN: 0658917501600
  • HAN: XVN-090D-1B-SK
  • Ruggedized 2-Antenna RTK GNSS/VINS
  • Speed: 0.1 m/s Mechanical
  • IP rating: IP67
  • Operating temperature: -30 to +85° C
  • Housing material: Aluminum
  • Connectors: M8 8-pin x3, M8 4-pin x1, SMA x3, USB-C x1
Discover the XVN-090D-1B-SK: a revolutionary stepper motor with incredible precision and performance. This impressive product offers unmatched accuracy and reliability for your most demanding applications. The XVN-090D-1B-SK features high torque density and exceptional rigidity, making it ideal for applications that require precise positioning. With an advanced stepper motor design, this motor offers unparalleled accuracy and repeatability to ensure your movements are always precise and reliable.
Thanks to its rugged construction and high-quality materials, the XVN-090D-1B-SK is extremely durable and reliable. It is designed for use in demanding environments, giving you long life and excellent performance. In addition, the XVN-090D-1B-SK is easy to integrate and operate. With its multiple connectivity options and intuitive controls, you can seamlessly integrate the motor into your existing systems. Whether you're in robotics, medical, automation or other fields, the XVN-090D-1B-SK is the perfect choice for precise positioning applications.
Rely on its outstanding accuracy, performance and reliability to meet your needs.
Specification:
  • Sensor Fusion Performance Roll, Tilt: <0.4 deg
  • Yaw/steer: 0.4 deg (1 m antenna baseline) Position accuracy with RTK: 1cm + 1ppm
  • Position accuracy with GNSS failures: 0.75% of distance traveled1
  • IP rating: IP67 Operating temperature: -30 to +85° C
  • Mounting position: facing the environment
  • Dimensions: 129*113.6*30 cm
  • Weight: 420g
  • Certificate: CE
Scope of delivery:
  • 1x Movella Xsens Vision Navigator Starter Kit - Ruggedized 2-Antenna RTK GNSS/VINS
Shipping weight: 6,00 kg
Item weight: 4,20 kg
Datasheet
€ 4.758,95
