NVIDIA Jetson AGX ORIN Module
NVIDIA Jetson AGX Orin Module
  • two versions; 32GB and 64GB
  • 15W - 60W
  • 16 lane MIPI CSI-2 connector
  • 64GB eMMC
The NVIDIA Jetson Orin NX module offers more than 6x the performance of the Jetson AGX Xavier in the same compactness for robotics and other autonomous machine applications.
With NVIDIA Ampere GPU architecture, deep learning and vision accelerators, high-speed IO, and fast memory bandwidth, this system-on-module supports multiple concurrent AI application pipelines. This can solve problems such as natural language understanding, 3D perception, and multi-sensor fusion.
The NVIDIA AI software stack is installed on the Jetson and application-specific frameworks are available (Isaac for robotics, DeepStream for image processing, and Riva for conversational AI). Time savings can be achieved by using the NVIDIA Omniverse Replicator for synthetic data generation (SDG) and the NVIDIA TAO Tool Kit for fine-tuning pre-trained AI models from the NGC catalog.
Technical data AGX Orin 32GB
  • AI Performance: 200 TOPS
  • GPU: 1792 Core Ampere, with 56 Tensor Cores
  • DL Accelerator: 2x NVDLA V2.0
  • Vision Accelerator: 2x 7-way VLIW Processor
  • CPU: 8-core Arm Cortex-78AE | 2MB L2 + 4MB L3
  • Memory: 32GB 256-bit LPDDR5 @ 2133HMz | 205 GB/s
  • Storage: 64GB eMMC
  • Video Encode: 1x 4K60 | 3x 4K30 | 6x 1080p60 | 12x 1080p30 | H.265, H.264, AV1
  • Video Decode: 1x 8K30 | 2x 4K60 | 4x 4K30 | 9x 1080p60 | 18x 1080p30 | H.264, H.265, VP9, AV1
  • Camera: 16 lane MIPI CSI-2 connector
  • PCI Express: up to 2x8, 1x4, 2x1 (PCIe Gen4, Root Port & Endpoint)
  • Mechanical: 100mm x 87mm 699-pin connector
  • Power: 15W - 40W
Techincal data AGX Orin 64GB
  • AI Performance: 275 TOPS
  • GPU: 2048 Core Ampere, with 64 Tensor Cores
  • CPU: 12-core Arm Cortex-78AE | 2MB L2 + 4MB L3
  • Memory: 64GB 256-bit LPDDR5 @ 2133HMz | 205 GB/s
  • Video Encode: 2x 4K60 | 4x 4K30 | 8x 1080p60 | 16x 1080p30 | H.265, H.264, AV1
  • Video Decode: 1x 8K30 | 3x 4K60 | 7x 4K30 | 11x 1080p60 | 22x 1080p30 | H.264, H.265, VP9, AV1
  • Power: 15W - 60W
Scopce of delivery
  • NVIDIA Jetson AGX Orin Module
from
€ 3.040,40
