Navio2 Plus Wire Set
  • SKU: MBS-Z-454
  • GTIN: 05390368407173
  • HAN: Navio2 Plus Wire Pack
  • Category: Pixhawk & RFD
Navio2 Plus cable set
  • 3 cables for UART, ADC and I2C, 200 mm
  • compatible exclusively with the Navio2 Plus
Navio2 Plus Wire Pack – cable set for UART, ADC and I2C ports
The Navio2 Plus Wire Pack contains three 200 mm connection cables for the extension ports of the Navio2 Plus. They allow external components such as telemetry modules, additional sensors or analogue signals to be connected to the autopilot quickly and without soldering.
The Navio2 Plus end features GHR connectors (JST GH), the other end standard 2.54 mm female jumper connectors – suitable for breadboards, pin headers and many breakout boards.
  • Complete cable set for UART, ADC and I2C of the Navio2 Plus
  • GHR connectors on the Navio side, 2.54 mm female connectors on the other end
  • Cable length 200 mm
  • Connect external components without soldering
Compatibility Navio2 Plus
Ports UART, ADC, I2C
Connector Navio side GHR 6-pin (UART, ADC), GHR 4-pin (I2C)
Connector other end 2.54 mm female (jumper)
Cable length 200 mm
Number of cables 3
Notes
  • This cable set only fits the Navio2 Plus. A separate Navio2 Wire Pack is available for the older Navio2.
  • 2× cable GHR 6-pin to 2.54 mm female (for UART and ADC)
  • 1× cable GHR 4-pin to 2.54 mm female (for I2C)
Shipping weight: 0,10 kg
Contact data
€ 24,95
  • Currently out of stock
