Orbbec3D Astra
- SKU: MBS-SES-56
- GTIN: 0096718603671
- HAN: Astra2018R3 / 100100010
- Category: Sensors
Manufacturers:
Orbbec3D Astra
- RGB 640 x 320Px with up to 30FPS
- Depth Images up to 30FPS
- Scan range: 0,6 - 8m
- USB 2.0 Port
ideally suited for usage in 3D scanning
The Orbbec3D Astra is an easy implementable 3D-Camera with a picture resolution of 640 x 320 Pixel with up to 30FPS. The depth resolution framerate is 640 x 480Px at 30FPS. The acquired data can be used in multiple ways via the USB Port. Below are some of the current fields of applications listed that the Orbbec3D Astra finds it use:
- Robotic / Autonomous systems
- Quality check
- 3D-Scanner / Full Body Scanner & Handheld
The large spectrum of possible applications is only achievable through the outstanding hardware aswell as well-engineered software and driver packages that also result in Orbbec3D Astra to be compatible with ROS, OpenNI, Astra SDk and much more.
The whole sortiment of Orbbec3D software products such as the Windows or Linux driver, the Orbbec3D Unity Engine, or the Body Tracking SDK can be downloaded for free and without any registration needed using the following link: https://orbbec3d.com/develop/
Special Features of the Orbbec3D Astra
The Orbbec3D Astra is provided with a large variety of 3D Scanning software such as RecFusion.
- Depth Images: 640 x 480Px 30FPS
- RGB Resolution: 640 x 320Px
- FOV: 60H 49,5V 73D
- Dimensions: 165 x 30 x 40mm
- Scanning range: 0,6 - 8m
- Data transfer & Power: USB 2.0
- Power consumption: < 2,4W
- 1 x Orbbec Astra 3D-Camera
| Item information | Value |
| Shipping weight: | 0,61 kg |
| Item weight: | 0,31 kg |
