Phidgets Brushless 42DMW61 NEMA17 106:1
  • 24V gelich current motor
  • 4mm key on shaft
  • 106:1 planetary gear
This Phidgets motor is a 24V brushless DC motor which can produce 190kg-cm of torque at 38rpm.To improve the coupling, the shaft is equipped with a 4mm key.
With its built-in Hall-effect sensor, these motors provide convenient position and speed control.
This motor must be controlled by a brushless DC motor controller. This must be able to send control signals to the three motor cables and read the Hall effect feedback from the other five cables.
  • 1x Phidgets Brushless 42DMW61 NEMA17
  • 1x 5-pin Molex connector
€ 138,95
