Pixhawk M8N GPS
Pixhawk M8N GPS
  • UBLOX M8N Module
  • IST8310 compass
  • tricolor LED display
  • Safety switch
  • PX4 firmware stable release v1.12.2 or newer
The M8N GPS from Holybro has a Ublox M8N module, an IST8310 compass, a three-color LED display and a safety switch. The baud rate of the module is 38400 5Hz and has different connection options for different purposes.
  • Ublox Neo-M8N module
  • Navigation sensitivity:167dBm
  • Cold start: 26s
  • LNA MAX2695ELT+
  • 25 x 25 x 4 mm ceramic patch antenna
  • Rechargeable Farah capacity
  • Low noise 3.3V regulator
  • Current consumption: less than 150mA at 5V
  • LEDs with fixed indicator
  • Protective housing
  • Cable: 26cm
  • Diameter: 50mm (total)
  • Weight: 32g with housing
Attention PX4 autopilot users
  • The GPS RGB LED driver chip has been updated - PX4 firmware stable release v1.12.2 or newer.
  • In case you are not able to perform normal compass calibration, set COMPASS_ORIENT=6 (Yaw270) parameter for proper compass alignment.
  • Pixhawk M8N GPS
Contact data
€ 62,95
  • Currently out of stock
