Professional Grade Magnetometer RM3100
  • SKU: MBS-SES-167
  • GTIN: 8944595424679
  • HAN: 0893B06
  • Category: UAV / Pixhawk
  • RM3100 Sensoren Set
  • JST-GH 4 Pins Connector
  • JST-GH 6 Pins Connector
Eliminate one of the biggest sources of error for drones to get better magnetic field readings.
The Drotek Professional Magnetometer RM3100 is a ready-to-use module that can eliminate any noise from magnetic field measurements to achieve accurate route and direction calculations. Give your drones a heading reference so they can navigate waypoints and eliminate magnetic interference from motor coils and metal parts. Based on PNI's proprietary magnetic induction technology, this 3-axis magnetometer offers high resolution and repeatability.Compared to leading Hall-effect sensors, resolution is increased by more than ten times and noise is reduced by more than twenty times.
The very high resolution (10 nT) that dases professional magnetometer RM3100 offers with low power consumption and no hysteresis and can be used for applications that require high accuracy. Use this module very easily without the need for temperature calibration.
  • 1x Professional Grade Magnetometer RM3100
Shipping weight: 0,20 kg
Item weight: 0,20 kg
€ 69,95
