Pudu charging station
  • SKU: MBS-Z1-252
  • GTIN: 0658917505004
  • Category: Accessories
Pudu Charging Station
  • Compatible with:
    • FlashBot Max
    • KettyBot Pro
    • PUDU T300
    • PuduBot 2
  • Operating voltage: 100 V–240 V AC, 50/60 Hz
Charging Station – Automatic Charging for Pudu Robots
The charging station allows the robot to automatically return and recharge without human intervention, significantly improving robot work efficiency and ensuring uninterrupted operation.
Accessory Highlights
  • Automatic charging: The robot autonomously returns to the charging station and charges, extending working time.
  • Multiple charging schemes: Using specific algorithms, various charging scenarios are implemented, e.g., idle-time charging, peak-time operation, or supplementary on-the-go charging.
  • Customizable charging plans: Can be configured for different robot types and environments to make the charging process intelligent and efficient.
  • Battery monitoring: Real-time battery status monitoring to initiate charging promptly and avoid work interruptions.
  • Charging management: Records charging times and battery levels for easy management and statistics.
  • High compatibility: Suitable for all Pudu delivery robots with automatic charging function.
  • Power output: 29.4 V DC / 3.5 A, 29.4 V DC / 8 A, 29.4 V DC / 15 A
  • Weight: approx. 3 kg
  • Dimensions: 390 × 390 × 165 mm
  • Noise level: ≤ 55 dB(A)
  • Protection: IP20
  • Operating temperature: 0 °C to 40 °C
  • Storage temperature: -20 °C to 60 °C
  • Machine power:
    • DC 29.4 V / 3.5 A: 102.9 W
    • DC 29.4 V / 8 A: 235.2 W
    • DC 29.2 V / 15 A: 438 W
Compatible Products
  • FlashBot Max
  • KettyBot Pro
  • PUDU T300
  • PuduBot 2
  • Charging station (main unit)
  • Power cable / adapter
  • Installation manual & documentation
€ 867,95
