ROBOTIS Touch Sensor TS-10
- SKU: MBS-SES-441
- GTIN: 05390368407166
- HAN: 902-0038-000
- Category: Sensors
Manufacturers:
- 5-pin cable, 150 mm
- Switch-based sensor
- Contact detection
ROBOTIS Touch Sensor TS-10 – touch sensor
The ROBOTIS Touch Sensor TS-10 is a switch-type sensor for detecting contact with objects. It is especially suited for robots that need to detect touch, impact or collisions – for example as a bumper on mobile robots.
| Sensor type | Touch sensor (switch) |
| Weight | 4 g |
| Dimensions | 24 × 18 × 15 mm |
| Connector | 5-pin |
| Manufacturer part number | 902-0038-000 |
Compatible controllers
- CM-100A, CM-150, CM-200
- CM-510, CM-530, CM-700
- OpenCM9.04, OpenCM7.0
- 1× Touch Sensor TS-10
- 1× 5-pin cable, 150 mm
