Realman Embodied Intelligent Arms Development Platform Dual
- SKU: ROB-RM-5
- GTIN: 0658917513238
- Category: Robot Arms
Manufacturers:
- 6-axis robotic arm with 5kg payload and 0.05mm repeatability.
- Integrated controller with Ethernet, WIFI, and RS485 communication.
- Flexible programming via tablet/computer; equipped with dual two-finger grippers.
The Realman Embodied Intelligent Arms Development Platform Dual is an advanced solution for industrial applications, research, and education. With six precisely controllable axes and a load capacity of up to 5 kg, this platform enables the execution of complex movements and tasks. Thanks to the built-in control unit and versatile communication options via Ethernet, WIFI, and RS485, the platform is both flexible and user-friendly. Its adaptability is enhanced by dual two-finger grippers, allowing versatile object handling. With the option of programming via tablet or computer, the platform is ideal for various applications such as automation, handling, and assembly.
Technical Specifications
- Control Axes: 6
- Payload: 5 kg
- Repeatability: 0.05 mm
- Work Radius: 626 mm
- Power Supply: DC24V
- Temperature Range: 0 °C to 45 °C
- Communication: Ethernet, WIFI, RS485
- I/O Interface: 4-channel reusable digital I/O
- Programming Options: Tablet/Computer
- Joint Rotations: J1: 178°, J2: 130°, J3: 135°, J4: 178°, J5: 128°, J6: 360°
- Max TCP Speed: J1-J2 180°/s, J3-J6 225°/s
- Gripper: Dual two-finger grippers, maximum opening width 65 mm, maximum load capacity up to 5 kg
Scope of Delivery
- 1x Realman Embodied Intelligent Arms Development Platform Dual
- 2x Two-Finger Grippers
- 1x Power Supply (DC24V)
- 1x Connection Cable Set
