SIYI Ethernet to HDMI Output Converter
  • SKU: MBS-SIYI-35
  • GTIN: 0658917599874
  • HAN: ETH-HDMI
  • Category: Accesoires
  • OSD overlay
  • MP4 recording
  • IP configuration
  • Compatible with SIYI HM30 Ground Unit, ZR10 Optical Pod, ZT30 Four-Sensor Optical Pod
Ethernet to HDMI converter
The Ethernet-to-HDMI converter from SIYI uses innovative video codec technology to convert a standard RTSP video stream into an HDMI stream via Ethernet. It is suitable for various applications and can be used flexibly.
Mavlink OSD overlay
It enables the insertion of Mavlink telemetry data into the HDMI signal as an OSD (on-screen display). This function offers an exciting FPV experience with full HD video and telemetry information in real time.
Real-time recording
The converter supports the recording of video streams on a TF/SD card in MP4 format. This makes saving and later playback of flight recordings particularly convenient.
Flexible settings
The converter can be configured via the TF/SD card to adjust IP addresses and RTSP streams or to switch the OSD on and off. Despite its compact size, the module offers numerous powerful functions.
  • SIYI Ethernet to HDMI Output Converter
Shipping weight: 0,50 kg
Item weight: 0,03 kg
€ 179,95
Docs MYBOTSHOP documentation
