SIYI HM30 Dual Link Fly More Combo
  • SKU: MBS-SIYI-11-02
  • GTIN: 0658917501020
  • HAN: SYHM30-DL
  • Category: Accesoires
  • digital wireless full HD image transmission system
  • 150ms
  • Range: 15km (with omnidirectional antennas), 30km (with long range antennas)
  • OLED touch screen
  • Quick release device
  • Firm- und Software: “Dual Operator” and “RC Relay” features
The HM30 Ground Station is a digital and wireless full HD image transmission system. The HM30 can achieve a range of up to 30km. The 1080p full HD video connection happens with an MS value of about 150. The transmitter is based on the latest image transmission technology, which was independently developed by SIYI Technology.
Due to its variety of functions and strong performance, HM30 is one of the commonly applied devices of reliable FPV view and solid control on FPV aircraft, commercial drones, unmanned vehicles and boats and robotics.
The HM30's technology has an intelligent function to adjust the transmission to the frequency bands with the least interference. As standard, it is equipped with omnidirectional antennas. These offer a range of up to 15km. With the Long Range antennas the range can be doubled.
HM30 supports the Dual RC function. Here two transmitters can be connected to one receiver to control flight and payload simultaneously. This RC relay function extends the radio control and image transmission range. (These functions are still under development and will be available soon).
The HM30's OLED touchscreen displays real-time link status and supports quick parameter configuration.
The transmitter's power supply is equipped with a quick-release device for common battery models (such as NP-F550/570/950- series). To charge the battery through the transmitter, max 30W PD fast charge may be used. The alternative is a 7V-20V external power through the XT30 connector.
Technical data HM30 Ground Unit
  • Working Time Monitor: 0,96" OLED Screen
  • Dimension (antenna and battery excluded): 109 x 61 x 28 mm
  • Weight (antenna and battery excluded): 132g
  • Working Temperature: -10°C ~ 50°C
  • Supported battery: NP-F970 / F750 / F550 / F770 / F950 quick release battery (HM30 Fly More Combo Comes with NP-F750 battery)
  • Charging: PD 30 W fast charging
  • ANtenna gain: Omni Antenna: 5dbi / Long Range Antenna: 11dbi
  • Power consumption: 5W
  • IP class: IP53
Technical data HM30 Air Unit
  • Signal Output: 16CH SBUS, 5CH PWM
  • Interfaces: SBUS (remote Control Signal Output), UART (Datalink Output to FC), PWM (PWM Signal Output CH 1 to 5), Ethernet (Video strea Input), Type C (Firmware update)
  • Dimension (antenna excluded, fan included): 70 x 55 x 24 mm
  • Weight (antenna excluded, fan included): 74g
  • Antenna gain: 5dbi
  • Working Voltage: 11 ~ 16,8 V (expandable to 14~58,8V with BEC)
  • Telemetry Voltage: 15 - 50 V
  • Working Temperature: -10°C to 50°C
Technical data FPV Camera
  • Camera Angle (FOV): 120°
  • Resolution: max. 1080p @30fps
  • Dimension: 42 x 42 x 25 mm
  • Weight: 23g
  • Antenna gain: -10°C to 50°C
  • SIYI HM30 Dual Link Fly More Combo
    • 2x HM30 Ground Unit
    • 1x HM30 Air Unit
    • 1x IP Camera
    • 2x Quick Release Battery
    • 2x PD Fast Charger
    • 4x Long Range Antenna
Shipping weight: 2,10 kg
Item weight: 2,00 kg
€ 1.438,95
