UAV RFD 900ux Long Range Modem
  • SKU: MBS-Z-151
  • GTIN: 0618455049910
  • HAN: MODEM-RFD900ux
  • Category: Accesoires
UAV RFD 900ux Modem
  • > 40 km Range
  • 1W Transmission power
  • small Dimensions
  • easy Implementation
Please note that without the appropriate radio operator license, the transmission power must be throttled to 25mW.
The UAV RFD 868ux is a modern telemetry modem used for data transmission with a transmission power of 1W, allowing a maximum range of up to 10km. The implemented firmware is an Open Source development enviroment called "SIK". The firmware is based on a 32bit ARM Prozessor and can be configurated via an FTDI converter.
  • Frequency Spectrum: 902-928 MHz
  • Transmission power: 1W
  • UART transmission rate: 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400, 460800, 1M baud
  • Reciever sensivity : < 111 dBm
  • Dimensions: 25 x 33 x 10,4mm
  • Weight: 10g
  • Working voltage: 5V @ 800mA
  • Working temperature: - 40 to 85°C
Interfaces
  • RF: 2 x u.FL/IPX
  • Serial TTL (3,3V)
  • GPIO: General purpose IO (Digital capable)
  • 1 x RFD900ux Modem
Shipping weight: 0,02 kg
Item weight: 0,02 kg
RFD CE / EU Declaration
€ 150,95
