Voltera V-One Rivets
  • SKU: MBS-VOLT-13
  • Category: Voltera
  • to connect the layers
  • effective solution for through-hole plating
Connect your top and bottom layers with Voltera rivets. The copper rivets provide you with a mechanical connection of both layers. This is a simple and effective solution to create a through-hole connection. For the optimal application, we also offer you the corresponding riveting tool.
Specification
  • Inner diameter - 0.4 / 1 mm
  • Head diameter: 0.9 / 2.2 mm
  • Drill size: 0.7 / 1.6 mm
  • 200x Rivets
Size
€ 19,95
  • Available immediately
