onRobot Vacuum gripper
- SKU: MBS-G-25
- Category: Gripper
Manufacturers:
onRobot vacuum gripper
- two versions: VG10 and VGC10
- electric and flexible
- Double gripper function
- payload: 10-15kg
- Integrated software
The electric vacuum grippers from onRobot are flexible and can cover a wide range of applications. They do not require an external air supply, which reduces maintenance costs and increases efficiency and productivity due to the double gripper function. In addition, software is integrated, which enables quick integration and deployment.
Why the VG10?
The electric vacuum gripper is a compact and mobile solution as it does not require a compressor or air supply. It allows more flexibility in the production line and reduces maintenance costs. Due to its flexibility, the VG10 is able to handle different objects in different sizes.
The left and right sides can be controlled independently, further increasing productivity. This vacuum gripper is specially designed for collaborative robotic applications. The suction cups are configurable and can be easily replaced. In addition, it has integrated software that is easy to install and program.
- Energy source: electricity
- Payload: 10kg
- Gripper mass: 1,7kg
- Acquisition time: 0,35s
- depositing time: 0,2s
- adjustable gripper arms
You can see the whole data from the datasheet.
Why the VGC10?
The electric vacuum gripper VGC10 is compact and has optional suction cups, which can be easily exchanged. Thus, it can be used flexibly. The VGC10 weighs only half that of the VG10 without sacrificing payload. Due to its two independently controllable air channels, the VGC10 is able to act as a double gripper with release and pick-up in one action. This reduces cycle time and increases efficiency. Production flexibility is ensured by the easy programming (integrated software). Moreover, it is easy to move as it does not need a compressor or air supply.
- Payload: 15kg
- Picking up time: 0,35s
The complete data can be taken from the data sheet.
- onRobot vacuum gripper
