ARK G5 P6 RTK GPS
- SKU: MBS-DR-73
- Category: Drones
Manufacturers:
ARK G5 P6 RTK GPS
- Centimeter-level RTK GNSS powered by Septentrio mosaic-G5 P6
- Dual-antenna heading, protected against jamming and spoofing
- Integrated magnetometer, barometer and IMU, connected via DroneCAN
ARK Electronics ARK G5 P6 RTK GPS – DroneCAN RTK GNSS module with Septentrio mosaic-G5 P6
The ARK G5 P6 RTK GPS is a USA-built, NDAA-compliant DroneCAN module that combines a quad-band RTK GNSS receiver, magnetometer, barometer, IMU and buzzer on one compact board. At its core is the Septentrio mosaic-G5 P6, which tracks all available GNSS signals across multiple constellations and frequencies and delivers centimeter-level positioning via RTK as well as Galileo HAS corrections.
The module can be operated with either one or two antennas. In dual-antenna mode it also provides the vehicle's heading – without relying on a magnetometer. AIM+ Premium technology protects against GNSS jamming and spoofing. It connects to Pixhawk flight controllers via DroneCAN, and firmware updates can be performed directly over DroneCAN.
Versions
The ARK G5 P6 RTK GPS is available in three versions:
| Version | Antennas | Dimensions | Weight |
| Without antenna | – | 48.0 × 40.0 × 15.4 mm | 13.0 g |
| With one antenna | 1× helical antenna (full frequency) | 48.0 × 40.0 × 51.0 mm | 43.5 g |
| With two antennas | 2× helical antenna (full frequency) | 91.5 × 40.0 × 51.0 mm | 91.0 g |
Septentrio mosaic-G5 P6 GNSS receiver
- All-in-view tracking: all available GNSS signals across multiple constellations and frequencies
- Quad-band reception
- Centimeter-level RTK positioning and Galileo HAS corrections
- Dual-antenna heading; single- or dual-antenna operation configurable by command
- AIM+ Premium: protection against jamming and spoofing as part of the GNSS+ algorithms
- Ultra-low power consumption
Technical specifications
| GNSS receiver | Septentrio mosaic-G5 P6 |
| Magnetometer | ST IIS2MDC |
| Barometer | Bosch BMP390 |
| IMU | Invensense ICM-42688-P (6-axis) |
| Microcontroller | STM32F412VGH6 |
| Protocol | DroneCAN, incl. firmware updates over DroneCAN |
| CAN | 2× Pixhawk standard, 4-pin JST GH |
| UART 2 (G5) | 4-pin JST GH: TX, RX, PPS, GND |
| USB (G5) | USB-C |
| Debug | Pixhawk standard, 6-pin JST SH |
| LED indicators | GPS fix, RTK status, RGB system status |
| Additional features | Buzzer |
| Supply voltage | 4.6–5.4 V |
| Current consumption | 360 mA |
| Origin | Made in the USA |
| NDAA | Compliant |
| Manufacturer part number | ARK-G5-P6-RTK-GPS |
Without antenna
- 1× ARK G5 P6 RTK GPS
- 1× Pixhawk standard CAN cable, 4-pin
With one antenna
- 1× helical GPS antenna (full frequency)
With two antennas
- 2× helical GPS antenna (full frequency)
- 1× SMA female to U.FL cable, 41 in (approx. 104 cm)
