AVerMedia Fan module designed for TX2 NX
  • SKU: MBS-AVM-17
  • GTIN: 0658917502140
  • HAN: TX2 NX fan module
  • Category: Electronics
  • Power consumption: 1W
  • Rate speed: 6000 RPM
  • Air Flow: 7.66 CFM
  • Noise Level: 31dBA
  • MTBF: 70,000 Hrs
AVerMedia Fan Module designed for TX2 NX - Efficient Cooling Solution
The AVerMedia Fan Module, specially designed for TX2 NX, offers an efficient cooling solution for your device. With its remarkable specifications, it's the perfect addition to enhance your system's performance.
Specifications:
  • Power Consumption: This fan module operates with low power consumption, using only 1 watt, contributing to energy efficiency while maintaining effective cooling.
  • Rate Speed: With a rapid rate speed of 6000 revolutions per minute (RPM), this fan ensures efficient air circulation.
  • Air Flow: The module provides an air flow rate of 7.66 cubic feet per minute (CFM), helping maintain optimal temperatures in your device.
  • Noise Level: Despite its performance, the noise level of this fan module remains at only 31 decibels (dBA), ensuring a quiet working environment.
  • MTBF (Mean Time Between Failures): With an impressive MTBF of 70,000 hours, you can rely on the long-term reliability of this fan module.
The AVerMedia Fan Module designed for TX2 NX is the perfect cooling solution to maintain optimal performance and temperature control for your device. Trust in its efficiency and reliability to keep your technology running smoothly.
  • 1x AVerMedia Fan Module designed for TX2 NX
€ 65,95
