AVermedia Box PC D135OXB Series
  • two versions
  • 216P5: 6x POE
  • 218G5: 8x GMSL2
  • Waterproof vibration resistant Fanless Edge PC w. Orin NX 16G
The AI Box PC D135 from AVerMedia is equipped with the powerful NVIDIA® Jetson Orin NX/Orin Nano module, offering efficient performance and comprehensive analytical capabilities for embedded IoT applications.
The D135 BOX PC is specifically designed for use in IP65/IP67 vehicle systems and features a wide range of waterproof I/O ports, enabling the rapid development and seamless deployment of AI-based solutions in demanding vehicle applications.
AVerMedia supports businesses of all sizes, offering customizable BSP services and flexible MoQs alongside the NVIDIA JetPack™ SDK. Stay ahead with AVerCooler—achieve up to a 5°C lower operating temperature under normal workloads, enhancing NVIDIA Jetson efficiency, extending lifespan, and delivering superior performance.
AVerMedia devices are designed with flexibility in mind and are tailored for the following vertical markets:
  • Autonomous Mobile Robots (AMRs): AMRs utilize live camera feeds to quickly and flexibly adapt work processes, leading to significant productivity increases.
  • Smart Security: Smart security systems leverage live camera streams and video analytics to improve and ensure community safety.
  • Smart Inspection: By utilizing live camera feeds, smart inspection systems enable fast and accurate defect detection, optimizing quality control in production.
  • Type: IP65/67 Box PC
  • NVIDIA GPU SoC Module Compatibility: NVIDIA® Jetson Orin NX / Orin Nano
  • External I/O (Waterproof)
    • 2x M12 X-Code for GbE with PoE 802.3af
    • 8x GMSL2 (FAKRA SMB Plug Z-code)(Optional)
    • 4x PoE (M12 X-Code 8pin, with PoE 802.3af) (Optional)
    • 1x M12A-Code (Isolated CAN BUS 2.0 Port With Transceiver, 2 port)
    • 2x M20 USB 3.0(Type A)
    • 1x M12 A-Code 12pin(4x GPI & 2x GPO & 1x RS485)
    • 1x M12 B-Code 5pin Power Input
  • Internal Slot
    • 1x M.2 M key 2280 (256G SSD pre-install)
    • 1x M.2 E key 2230 (WIFI)
    • 1x M.2 B key 3052 (4G/5G) QuectelRM520n-GL ANT0/1/2 for 5G , ANT3 for 5G or GNSS
    • 1x mPCIe(IMU/GPS)
  • Repair Area with an Access Panel with O ring for waterproof
    • 1x Recovery mode push button
    • 1x DIP switch for CAN terminal selection1x USB 3.1 Type-A port
    • 1x GbE RJ45 port
    • 1x HDMI type A port (4Kp60)
    • 1x USB-C (BSP flash)
    • 1x USB-C UART port (Debug)
    • 2x Nano SIM card slot (4G/LTE/5G)
  • Misc(Optional): Accelerometer , IMU 6-Axis motion tracking, Super CAP(Optional)
  • OOB (Optional): AllxonOOB
  • Storage temperature: -40°C ~ 85°C
  • Power requirement: 12V/5A,DC Input Range 9V~36V is recommended (M12 B-Code 5 pin)
  • RTC Battery: Support RTC battery and Battery Life Monitoring by MCU
  • Verification: MIL810G for vibration (TBA), IP67 (TBA)
  • Dimensions: W: 300mm * L: 153mm* H: 103mm(T.B.D)
  • Weight: 4Kg (T.B.D, BOX PC)
  • Certifications: CE, FCC, KC (TBA)
  • AVermedia Box PC D135OXB
Shipping weight: 5,00 kg
Item weight: 4,30 kg
from
€ 4.299,95
