NVIDIA Jetson Orin NX
  • two versions: 8GB and 16GB
  • 32 Tensor Cores
  • 10W to 25W
  • PVA v2.0
The NVIDIA Jetson Orin NX module offers 3x the performance of the NVIDIA Jetson AGX Xavier and 5x the performance of the NVIDIA Xavier NX, making it ideal for small form factor, low power products such as drones and portable devices.
With NVIDIA Ampere GPU architecture, deep learning and vision accelerators, high-speed IO, and fast memory bandwidth, this system-on-module supports multiple concurrent AI application pipelines. This can solve problems such as natural language understanding, 3D perception, and multi-sensor fusion.
The NVIDIA AI software stack is installed on the Jetson and application-specific frameworks are available (Isaac for robotics, DeepStream for image processing, and Riva for conversational AI). Time savings can be achieved by using the NVIDIA Omniverse Replicator for synthetic data generation (SDG) and the NVIDIA TAO Tool Kit for fine-tuning pre-trained AI models from the NGC catalog.
Technical Data Orin NX 8GB
  • AI Performance: 70 TOPS
  • GPU: 1024 Core Ampere, with 32 Tensor Cores
  • DL Accelerator: 1x NVDLA V2.0
  • Vision Accelerator: PVA v2.0
  • CPU: 6-core Arm Cortex-78AE | 1.5MB L2 + 4MB L3
  • Memory: 8GB 128-bit LPDDR5 @ 2133HMz | 102.4 GB/s
  • Video Encode: 1x 4K60 | 3x 4K30 | 6x 1080p60 | 12x 1080p30 | H.265, H.264, AV1
  • Video Decode: 1x 8K30 | 2x 4K60 | 4x 4K30 | 9x 1080p30 | H.264, H.265, VP9, AV1
  • Camera: up to 4 cameras (8 via virtual channels) 8 lanes MIPI CSI-2 D-PHY 1.2 (20 Gbps)
  • PCI Express: 3x1 + 1 (x4 PCIe Gen 4)
  • Mechanical: 69,6mm x 45mm 260-pin connector
  • Power: 10W / 15W / 20W
Technical Data Orin NX 16GB
  • AI Performance: 100 TOPS
  • DL Accelerator: 2x NVDLA V2.0
  • Memory: 16GB 128-bit LPDDR5 @ 2133HMz | 102.4 GB/s
  • Power: 10W / 15W / 25W
from
€ 1.129,95
  • Available immediately
Others also bought:
